Minor Annoyances: Auto-complete commands, right-click menu, and OSnap/DynamicInput toggling
Was wondering if anyone else has run into these issues and if they've found a solution:
1. About 50% of the time, the auto-complete command feature works as intended. Usually I can, for example, type AEW then quickly hit Enter before auto-complete pops up, and it will pick up that I meant AEWIRE and execute the command. The other 50% of the time, I will start to type the command, and nothing will auto-complete. The letters just sit in the CMD line with nothing happening, no matter how long I wait. If I press Enter, the CMD line returns the "Unknown command" error (it misbehaves for all kinds of other commands as well, ACAD and ACADE). There is no rhyme or reason to when it will behave or malfunction.
2. Also about 50% of the time, when I select a component and right click, it will bring up the radial shortcut menu, I'll make a selection as normal, but then it will immediately display the regular AutoCAD right-click menu as if I had right-clicked in empty space. I will hit Esc or click out of the right-click menu and it will go to whatever command I chose initially from the ACADE radial menu. Then when I exit out of whatever command window it was, my cursor behaves as though I was in the middle of dragging a selection box. I can't seem to pin down the circumstances that cause it to do this. It's not a huge hindrance, but it just slows me down and interrupts me.
3. Lastly, and this is the most intrusive, my Object Snap and Dynamic Input settings will randomly turn on and off. I ALWAYS want Dynamic Input turned on because of personal preference. As for the OSnaps, sometimes the entire feature gets turned off, and sometimes an arbitrary number of snaps types get toggled on or off. Like I will end up with OSnaps turned on, but only the "Nearest Point" snap will be activated, which I never use. Or I will turn on OSnaps just for it to be turned off a few minutes later. It honestly feels like someone is messing with me!
The combination of these three things is driving me crazy. We just got brand-new PC's at work with 16GB of RAM, i9 processors, and high-end graphics cards, so I don't think it could be a performance issue. What's going on here??
