Make schematic Text bolder
mrshayboo
mrshayboo
Whenever I use the Publish> Publish to PDF/DWF/DWFx (via right-click on project) for a mulitsheet pdf file, The schematic always seems much lighter than if I use Print>Plot which makes seeing the decimal point or other things difficult to read. I think the lines are fine, more so the text which isn't as bold as we would like.
When using Print>Plot, I tick Plot Object Line weights in Plot options but using the Publish> Publish to PDF/DWF/DWFx doesn't allow me to select to plot object line weights. I have ticked the option via PAGESETUP, and when I choose that setup through the Publish option, it still doesn't make a difference.
I am currently using WD_IEC style font across schematic, so maybe I should change that? If this is the issue, any links as to how to do this globally?
I have checked the .fmp file and it shows romans;RomanS_IV50.TTF
and also i have made AEPDFFONTALT = OFF
Multi-sheet File PDF via Publish
PDF via Print>Plot
Radwan-Almsora
To fix the faded text issue when publishing a multi-sheet PDF in AutoCAD Electrical, the most reliable solution is to globally change your font from an SHX font (like romans) to a TrueType font (like Arial), or properly map your Page Setups within the Publish dialog.
mrshayboo
Thanks for the advice, is there a way to globally change the font? As the current font is same across wire numbers, colour/gauge labels, component descriptions, component terminal numbers etc. Is there a way to change all these at once, or would I have to go into each component to change the font style of those separately?
pkomatlapalli
Hi @mrshayboo ,
I wanted to follow up to see whether you still experiencing the issue? If so, please provide additional details or If you have already found a solution, we encourage you to share it with the community so that other members with similar questions may benefit from your experience.
Pavan Kumar | Community Manager
Radwan-Almsora
Yes, you can globally change all your fonts at once rather than editing each component individually. Since your labels share uniform properties, they are likely grouped under a single Text Style (often named "WD" or a variation), or are controlled globally by your software settings.
I belive this was answered here:
Setting default font style for AutoCAD Electrical drawings
