layer color
layer color
pcwortex
layer color
pcwortex
I want to organize the template file so that every time a new drawing is created using the template, I don't have to go to the layers and change the colors. I have added a video. Maybe you can advise me on how I can handle this.
(view in My Videos)
rhesusminus
When creating a new sheet, are you asked to insert the WD_M block?
This is the block that contains the layers used, and the correct settings. I'd recommend that you insert the WD_M and WD_PNL blocks in the template, so that you're not asked to insert it. Also, make sure the layers are correct in your template/DWT.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
pcwortex
If I understand you correctly, you're talking about the WD_M block attribute. I opened the Block Attribute Manager but don't understand which attribute is responsible for the element tags and Terms layer color. I tried comparing it with another template's WD_M block attribute, but I couldn't find which one is responsible for the element tags and Terms layer color
pcwortex
It looks I fixed the error. The problem was that one block inside my template had WD_M. I deleted it and created a new template file without the WD_M block, but when I use this template, the WD_M block is inside. It’s probably being inserted automatically into the template. It seems to be working well now. However, if I want to have a different color layer, how can I change the default layer colors? Should I create a template file with the layer colors I want?
rhesusminus
The WD_M.DWG block is what controls this. Open it and have a look at the layers there.
Trond Hasse Lie
Ctrl Alt El
rhesusminus
But, yes. You should set up the layers correctly in you DWT template.
Trond Hasse Lie
Ctrl Alt El
