component tagging issues
rickstarosto4361
rickstarosto4361
Before I waste too much time, our projects normally have 4 different “installation” =A01, =Sxx, =Hpp and =Kqq and across these locations I could have 4 components with the same TAG “MDL143”. The way I have our component suffix set up as I go across the project insert a MDL143 (in =A01) the next installation ends up as =Sxx-MDL1431, next is =Hpp-MDL1432 and finally =Kqq-1433.
These are 4 distinctly different installations, so we do have many various components with the same Tags just various installations. In the drawing properties I do have the “installations” noted and I thought that is what I needed to do, but obviously not.
Again, thanks in advance for the help!
rhesusminus
And you have enabled the use of installation/location codes in the project properties as well?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
rickstarosto4361
i guess not, not sure  where and which box to check if i am in the proper area of properties?
rickstarosto4361
I believe i figured it out!
Thanks Again!!!!
rhesusminus
As long as "combined installation/location tag mode" is enabled, the _complete_ tag of the component is =INSTALLATION+LOCATION-TAG1
This combination has to be unique in the project.
What problems are you experiencing? Can you share a test-project?
Trond Hasse Lie
Ctrl Alt El
rickstarosto4361
Got It!
Something else learned👍
