AutoCAD Electrical Forum
ladder rung text
2 REPLIES 2
376 Views, 2 Replies
ladder rung text
My autocad electrical 2020 has changed again after reloading the software. The dash in between the line and sheet number is placed at the top of the numbers instead of the center where it belongs. This really looks bad on a drawing. Does anyone know how to correct this without having to reload the software again. A picture is inserted below. It seems that various text like wire numbers are harder to read also. Anyone have an idea what has happened here?
2 REPLIES 2
chris.downing
Can you send a copy of the project settings?
ACADE & PLANT3D Applications Engineer
CAD Training
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
JeffatPrimex
The option sheet-number looks to be using the WD_MLRH7 block. If you open that block you might be able to determine why the dash is not lined up.
Best regards,
Jeff
