AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
INSERT A TITLE BLOCK SCRIP
1 REPLY 1
389 Views, 1 Reply
I am trying to insert a title block with a script, from one drawing to other, so im using this:
_-insert "P:\Protecciones\ACE_IEC_a3_Color.dwg"
0,0
1
1
0
but when y try to update the titles this error appear
Could not find instance of title block name=IEC_TBLOCK_A3,H12-COMANDOS REMOTOS B650
(references in "BLOCK=" part pf the .WDT file)
1 REPLY 1
JeffatPrimex
Just a guess but it sounds like the file ACE_IEC_a3_Color.dwg being inserted has a xref associated with it called IEC_TBLOCK_A3,H12-COMANDOS REMOTOS B650.dwg.
If this is the case try putting the xref in the same directory as the file you are running this script on.
Best regards,
Jeff
