AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Issue with project wide update for ladder references
4 REPLIES 4
537 Views, 4 Replies
I think I have found a glitch with project wide update.  I had to update my ladder references.  After it was done, I noticed that blocks with fixed tag became unfixed and I had to go back and redo all my fix tags.
4 REPLIES 4
ChrisPreece
Hi @Anonymous,
Does this issue occur in all drawings and projects, or is it specific to certain files? After updating your ladder references, were you able to re-fix tags project wide?
Chris Preece
Technical Support Specialist
in reply to: ChrisPreece
I did the ladder update for all of my electrical drawings. All blocks with fixed tags were changed on all the drawings. I had to manually click to make the tag fixed and put change to tag to the correct tag number.
ChrisPreece
Hi @Anonymous,
Is this issue still present? I'm not able to reproduce it on my end, so I'm wondering if you could record a Screencast and send me the link.
Chris Preece
I think this might be a case of me thinking I fixed the tag number. I tried it again and can't get it to happen again. Please close out this case. My apologies.
