I having problems with placing terminals by using the terminal footprint editor on the Panel tab.
All goes well untill I actually place the terminal. Only the outline becomes visible, but the inner lines are invisible unless I select it. See attachment.
All layers are on, and I can't find a setting which I need to change or something.
Anyone else have this problem? Any solutions?
Thanks in advance
Solved by rhesusminus. Go to Solution.
