AutoCAD Electrical Forum
Invisible terminals
2 REPLIES 2
697 Views, 2 Replies
Invisible terminals
I having problems with placing terminals by using the terminal footprint editor on the Panel tab.
All goes well untill I actually place the terminal. Only the outline becomes visible, but the inner lines are invisible unless I select it. See attachment.
All layers are on, and I can't find a setting which I need to change or something.
Anyone else have this problem? Any solutions?
Thanks in advance
2 REPLIES 2
rhesusminus
Seems like the block contains a wipeout object. Open one of the terminals in the block editor and use the DRAWORDER-command to move the wipeout behind the other geometry in the terminal footprint. When you exit the block editor, and select yes to save changes, all terminals of this type should be fixed. Of course, this should also be done in the footprints original DWG-file...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Thank you,
Never knew this, but I didn't enter the block editor, I just selected all, and by right clicking slecter the draworder -> bring to front. The block itself is okay, I don't have this problem when I place these blocks seperately, only when using terminal editor.
But it is solved 🙂 so Thank you
