Insert / Edit Child Component - Error
Message 1 of 9
An error is showing when I insert the child component. I can't click the Drawing, Project & Parent/Sibling Buttons (it's not working). I can only press Cancel Button.
Replies (8)
Message 2 of 9
rhesusminus
If this applies to all child symbols in all projects, I would do a reset of AcadE...
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 9
The same error is showing ..... (Please check the attached Video File)
Extracting item numbers in use . . .
Error: LOAD failed: "C:\\Users\\admin\\AppData\\Local\\Temp\\iec_insert_sec_trmDlgEvents.lsp"_.UNDO Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: _END _.ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: 1.0X
Message 4 of 9
jseefdrumr
If the reset didn't work, I would next try a Repair. If that also fails, a re-install of the software is probably in order. Both options are available in Add/Remove Programs.
If you need to re-install, first be sure that you have all the necessary permissions (meaning full read/write access) in any location where ACADE puts its files. This includes anything on a network. Personally, I always set a CAD station to have administrator privileges.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 5 of 9
Sebinrose, here's what you should see in console when you insert a schematic component:
Specify insertion point:
 Retrieving project-wide component tags in use...
 reading project database file . . .
Command: *Cancel*
Are you sure that your project is setup correctly, and that your active drawing is in the project?
ACADE is a pretty finicky program. As soon as you start seeing "lsp" errors, it's likely that nothing but a full Repair or Reinstall will solve the issue. I've had this many times when the mouse reactor (the ACADE custom right-click menu) stops working.
Unrelated: I noticed you aren't using SNAP - I would highly recommend turning this on, so you can be sure your wires meet up and that components land correctly.
Message 6 of 9
I fixed this problem just running the program as an admin user. You can configure this application to always run as an administrator (link). I hope you'll find it useful.
Message 7 of 9
lou.branchaud
I'm currently experiencing this problem, only I'm not getting an error code and none of the solutions fixed the problem.
Message 8 of 9
normeo.2016
In my case, the reason is that the TEMP folder was on disk D - I always transfer after installing windows. Returned the user environment variables Temp and Tmp to "default" and everything worked
Message 9 of 9
lou.branchaud
Interesting, my re-installed copy seemed to have worked.  Whereas my original ACADE was on my D drive.
That's helpful.  Thanks
