Hi.
I'm tasked with creating a few eletrical blocks and I would like it to display some extra information when I plot it from the catalog browser. I created a new catalog using the Autocad eletrical, which is completely empty. Then I added a new family SE(sensors) and created a block and added the description to the catalog. Using the Microsoft Access, I edited the database collums to have the headlines I wanted, "Accuracy", which is the collum feed with the informating I would like the block to fetch and display. Using the Cad Symbol Builder, I added a new attribute in the optional row and named it "Accuracy", exactly as it's labeled in the database.
Now the issues I'm having. 1 - The "Accuracy" tag is not being displayed at all. Nor the number, nor as a plain text. 2- It's also not showing up in the list if I open the Symbol Builder Editor, but is does show up in red if I double click the block.
Does anyone knows how to do what I want? Thank you in advance.
To try tok simplefy my question. If I insert a motor from the catalog browser, is is possible to display the Motor's HP as an Attributre? How do I do that?
The topic title has been edited to improve findability by @alina.balkanskaia. Original: Adding and displaying information from the calatog database in eletrical blocks
Solved by rhesusminus. Go to Solution.
The only way to push values from the catalog to the symbol is to use the TEXTVALUE field in the database.
Accuracy=123ABC
will push "123ABC" into the accuracy attribute.
Read more about this here: https://knowledge.autodesk.com/support/autocad-electrical/learn-explore/caas/CloudHelp/cloudhelp/201...
