During converting PDF files to DWG , How can I maintain Line Properties, for example when converted to PDF from DWG, Dotted lines are changed to Continuous Lines. Please help me with a solution to maintain the properties.
If "Infer linetypes from colinear dashes" is checked, AutoCAD will make a "guess" that this might be a dashed linetype, but there's no guarantee the this will work.
There are no other ways to achieve this.
thankyou Very much for your answer .
Unfortunately, the dotted lines are not coming out. only i get continued lines after trying with your solution
ok I share with byou the pdf. I just wanted the Dotted lines as it is while converting to DwG. After converting the line seems to be continuous .
its possible to change after conversion but , i have to insert about 46, pdf files and to convert to DWG and then i have to make the changes.My question is it possible to get the exact type of lines from from pdf when converted to DWG. So i can save time when i make changes to the drawings
