How to maintain Line properties While inserting a PDF diagram? Circuit Diagram
This widget could not be displayed.
During converting PDF files to DWG , How can I maintain Line Properties, for example when converted to PDF from DWG, Dotted lines are changed to Continuous Lines. Please help me with a solution to maintain the properties.
Replies (7)
rhesusminus
If "Infer linetypes from colinear dashes" is checked, AutoCAD will make a "guess" that this might be a dashed linetype, but there's no guarantee the this will work.
There are no other ways to achieve this.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
thankyou Very much for your answer .
Unfortunately, the dotted lines are not coming out. only i get continued lines after trying with your solution
rhesusminus
Can you share the PDF?
What program was the PDF created with?
Trond Hasse Lie
Ctrl Alt El
ok I share with byou the pdf.   I just wanted the Dotted lines as it is while converting to DwG. After converting the line seems to be continuous  .
jseefdrumr
Is it not possible to just....change them to dashed, after the conversion?
Jim Seefeldt
Electrical Engineering Technician
its possible to change after conversion but , i have to insert about 46, pdf files and to convert to DWG and then i have to make the changes.My question is it possible to get the   exact type of lines from from pdf when converted to DWG. So i can save time when i make changes to the drawings
rhesusminus
Then you better get started. There's unfortunately no way to make AutoCAD recognize these line types.
Trond Hasse Lie
Ctrl Alt El
