how to delete a proxy entity
haiduken_ae_mi
Message 1 of 18
haiduken_ae_mi
have on in a drawing that I want to edit (a leader) and there is nothing that I am doing that is working. I tried exploding, purging and I cant remember what else and nothing seems to work... any ideas?
Replies (17)
Message 2 of 18
TRLitsey
Hi there,
Can you post up a drawing so we can take a look at it?
What version of ACE and OS are you using?
Will take a look tomorrow if this is still post.  It is the end of my day.
Thank you
Please mark as a solution if this works for you, kudos are always welcome
Message 3 of 18
jseefdrumr
I don't know if it works on proxy objects, but SuperPurge will forcibly remove things from a drawing that the normal PURGE command won't. A quick internet search will get you there.
Caution: be very aware of what you are doing with this command. It CAN and WILL break a drawing if you aren't careful.
Hope this helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 4 of 18
haiduken_ae_mi
This is the file i am having trouble with. The proxy entity seems to be the welding call out.
Message 5 of 18
jseefdrumr
Looks like you'll need to get an object enabler for this. I tried SuperPurge on it and it didn't work. Here's a link to the Autodesk Knowledgebase article on Object Enablers:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/ENU/123112/fil...
Hope this helps,
Jim
Jim Seefeldt
Message 6 of 18
TRLitsey
Hi there,
Proxy Object is a new one to me.  Reading in the Help area you may or may not be able to do anything with it unless you have to software that created the object.  You might find an Enabler as was suggested but that could take a little of your time.  For what this drawing is, not really a whole lot going on here, you might consider just creating a new drawing with the settings you want.
This one is kind of a bummer, sorry about that
Good luck
Please mark as a solution if this works for you, kudos are always welcome - thank you
Message 7 of 18
haiduken_ae_mi
thanks a lot for your help
Message 8 of 18
haiduken_ae_mi
thank you, i appreciate the help
Message 9 of 18
TRLitsey
Hi again,
Real quick down and dirt.  I copied everything but Proxy and pasted it into a new acad template drawing.  Will this work for you?
Message 10 of 18
haiduken_ae_mi
thanks that's what i ended up doing.
Message 11 of 18
I ran into the exact same issue. I found a workaround that works very well.
  1. select all proxy objects and use the explode command (I selected one proxy object, right clicked, and chose the select similar option)
  2. select all objects in the drawing and copy to clipboard with base point (0,0) (I used the command select, then typed all, right clicked and under the clipboard option I chose copy with base point)
  3. open a blank drawing
  4. paste to the same base point. (ctrl v and then enter (0,0))
  5. save the new drawing
  6. add xrefs from previous drawing or change xref links that were linked to the old drawing
Proxy objects cannot be deleted or COPIED, therefore, the new drawing you just created will not have the proxy objects. Hope this helped
Message 12 of 18
I found a work around for removing Proxy's
go and save your drawing as a AutoCAD R12/LT2 DXF (*.dxf) and after that close the drawing then open it back up and all the Proxy's are gone then you can save your drawing as an ACAD drawing again
Message 13 of 18
Select entity right click - isolate - hide object. i think this will help.
Message 14 of 18
I know of 2 options:
Easy option is use the proxyshow command, this will turn them off
or
Put them on a different layer and turn the layer off
have not found a way to remove them
Message 15 of 18
dominik.bujan
Observer
Observer
Worked for me. Thanks!
Message 16 of 18
controlsgirl
What if you can't see the object? proxy(no graphics)..
Message 17 of 18
rhesusminus
Try the EXPORTTOAUTOCAD command...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 18 of 18
controlsgirl
I'll give it a try the next time I'm bombarded with them. I have whole sets of drawings that have something on each page. I'm assuming its something for a title block.
