AutoCAD Electrical Forum
How to change the Wire Numbering field to either yes or no using API
2 REPLIES 2
alan_rackham
324 Views, 2 Replies
I just discovered today that I can use the following API call to add wire layers to AutoCAD electrical.  This manual does not show me how to update the Wire Numbering field.  Can anyone help?
(c:ace_mod_wiretype "RED-AWG" (list "SIZE" "14" "USER1" "XHW") nil)
2 REPLIES 2
that api is to modify existing wiretype, not sure why there isn't an option to toggle numbering.
You can use c:ace_new_wiretype to add a wire layer
Or possibly include "WIRENO" 0 (0 off/1 on) in your options list
James
Thanks for the information.  The final solution was:
(c:ace_mod_wiretype "WIRES_NORMAL" (list "WIRENO" "1") nil)
You need quotes around the number.  This should be in the API help, but it isn't
