On my old computer AutoCAD Electrical 2017 image 1 below had a white background and black letters, and on the new which is AutoCAD Electrical 2022 image 2 below has black background and white letters. How do I get it to back to the white back ground and black letters.
This is what I am getting on the AutoCAD Electrical 2022 which I do not want
image 1
This is what I am getting on the AutoCAD Electrical 2017 which is what I want it to look like
image 2
Solved by jnauerLV7JJ. Go to Solution.
Is this when printing? To PDF?
Make sure you have all updates for AutoCAD/AutoCAD Electrical installed. Use the Autodesk Desktop App to check if you have them installed.
It is going from a drawing to a PDF and I do have all updates to AutoCAD
In the image attached below is everything I put in before I print to PDF
Just to cover all the bases, in the drawing, does the logo look right? Or is it also reversed there?
No looks right in the AutoCAD drawing it has a white background but the letters have color to them
Do you get this problem both when publishing the project, and when printing a single page?
Can you try the DWG to PDF.pc3 driver that comes with AcadE, to see if that gives the wanted result?
Depending on your Adobe Acrobat version, there might be an incompatibility with you version of AutoCAD. You CAN upgrade Adobe, but I'd just go with what comes with AutoCAD Electrical.
