How do I fix the background on the image on the drawing?
jnauerLV7JJ
jnauerLV7JJ
On my old computer AutoCAD Electrical 2017 image 1 below had a white background and black letters, and on the new which is AutoCAD Electrical 2022 image 2 below has black background and white letters. How do I get it to back to the white back ground and black letters.
This is what I am getting on the AutoCAD Electrical 2022 which I do not want
image 1
This is what I am getting on the AutoCAD Electrical 2017 which is what I want it to look like
image 2
Replies (11)
rhesusminus
Is this when printing? To PDF?
Make sure you have all updates for AutoCAD/AutoCAD Electrical installed. Use the Autodesk Desktop App to check if you have them installed.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
jnauerLV7JJ
It is going from a drawing to a PDF and I do have all updates to AutoCAD
pendean
Community Legend
Community Legend
Which PDF driver did you use in each program?
jnauerLV7JJ
The PDF program I am using is Adobe Acrobat Pro
jnauerLV7JJ
In the image attached below is everything I put in before I print to PDF
jseefdrumr
Just to cover all the bases, in the drawing, does the logo look right? Or is it also reversed there?
Jim Seefeldt
Electrical Engineering Technician
jnauerLV7JJ
No looks right in the AutoCAD drawing it has a white background but the letters have color to them
rhesusminus
Do you get this problem both when publishing the project, and when printing a single page?
Can you try the DWG to PDF.pc3 driver that comes with AcadE, to see if that gives the wanted result?
Trond Hasse Lie
Ctrl Alt El
jnauerLV7JJ
Trying DWG to PDF that comes with AcadE worked.  Thank you
rhesusminus
Depending on your Adobe Acrobat version, there might be an incompatibility with you version of AutoCAD. You CAN upgrade Adobe, but I'd just go with what comes with AutoCAD Electrical.
Trond Hasse Lie
Ctrl Alt El
jnauerLV7JJ
Okay thank you
