How can I add separate wire numbers to wires that ACADE considers in the same network?
samuel_elliott6ZHZL
Observer Observer
samuel_elliott6ZHZL
Observer
Observer
Hello!
I have a wire network consisting of one main feed, a length of busbar, and several subfeeds. To do this, I represented the busbar as another wiretype. I would like to give the main feed and subfeeds separate wire numbers/descriptions but since ACADE considers everything I've put here as wires in the same network, it won't let me change the wire numbers of any of the subfeeds to anything different from the main feed.
Attached is a sample image of what I am trying to do.
vladop
samuel_elliott6ZHZL
Observer
Observer
This works, but is there by chance a more elegant solution for something like a right-angle connection?
vladop
These are attribute requirements for splice symbols:
X?WIRE01, X?WIRE02
Attribute for wire annotation. The "?" digit is the wire connection direction digit; 1, 2, 4, or 8.
TERMDESCxx
Attribute for wire connection description (128 characters maximum).
ACE_FLAG
Attribute with a value set to 1 to identify a splice symbol.
Modifying existing splice symbol, you can try to create a new splice symbol that looks like a right-angle connection. It must have an ACE_FLAG attribute set to 1.
I think a third Attribute for wire annotation X?WIRE03 should be added. The question is how it would work, but you can try.
I think some people use Terminal Symbols with a number change, which can also be modified to look like a right-angle connection.
arshdeepsingh404
Hi @samuel_elliott6ZHZL
Like @vladop mentioned, the terminal symbol with wire change might be alternative solution.
All the terminals that are labelled "with Wire Number Change" will cause the wire number to change. Similar to the splice symbol.
You can use them either as is or open the symbol and reverse engineer it to convert the geometry to a right angle symbol like you want.
I have also seen some people converting the terminal symbol into a dot.
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM | CMSE | Autodesk Expert Elite
LinkedIn | Autodesk App Store | GitHub
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
