From/To Reporting Not Showing Any Location Codes [AutoCAD Electrical]
Zerb
Zerb
I am attempting to use the Reporting features of ACADE to help me in my work flows but I am having an issue with the first report that I am trying to run.
I would like to know what wire numbers have a specific LINETYPE used within a project. I originally thought that I could perhaps run a report to look at the places were a certain LINETYPE was used, but that doesn't seem to be possible.
So, my plan was to create a new layer in the project, place the wires that I want onto it and then in the report generation for From/To, set it up so that the WLAY1 was in the Fields To Report and I could then see which wire numbers were all on a certain layer.
However, I cannot get the From/To report to generate anything. Pics are attached to show what I am looking at here. Thanks for any help.
@Zerb
The topic title has been edited to improve findability by @alina.balkanskaia. Original: From/To Reporting Not Showing Any Location Codes
rhesusminus
Try to select (??) for both sides.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Zerb
That did it, didn't even think to try the (??) just assumed that wasn't going to work. Now I see I have to Create/Edit a wire type then it will show up in that report that I can generate. Thanks!
Zerb
With that said is my method the most direct for what I am looking to accomplish?
-I have multiple drawings within a project
-Certain wires within those drawings all need to be accounted for on a single drawing within the project for connection points from the machine to the MCC once installed in the field.
-I have made separate layers for the (3) types of wires that I would like to keep track of.
-Now when all of my drawings are done within my project I can run that report and it will spit out what wire numbers are located on which layers and I can use that information, exported to an excel file, to then create my interconnection drawing.
Is there a way that ACADE would do that automatically for me? If I were to create a sheet with a bunch of non-numbered wires within the project, then once I added a wire to that specific layer on any sheet within the project it would automatically populate it on the interconnect sheet?
rhesusminus
Would your interconnect drawing be a one-line drawing?
And then again, arent' all connections between locations (location code/enclosure) cables? How about using cable markers? Then you could just get a cable from/to report.
Do you have an example of what you're trying to achieve? It's a little bit easier for me to help as I'm kind of "visual".
Send me a PM or e-mail ( t h l @ c t r l a l t e l . c o m ) if you don't want to share here.
Trond Hasse Lie
Ctrl Alt El
alina.balkanskaia
Hello, @Zerb! Happy to see you in Autodesk Community! Thank you for marking the correct answer as the Solution because it will be helpful for other users in the future.😀
Alina Balkanskaia
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
