How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
I am attempting to use the Reporting features of ACADE to help me in my work flows but I am having an issue with the first report that I am trying to run.
I would like to know what wire numbers have a specific LINETYPE used within a project. I originally thought that I could perhaps run a report to look at the places were a certain LINETYPE was used, but that doesn't seem to be possible.
So, my plan was to create a new layer in the project, place the wires that I want onto it and then in the report generation for From/To, set it up so that the WLAY1 was in the Fields To Report and I could then see which wire numbers were all on a certain layer.
However, I cannot get the From/To report to generate anything. Pics are attached to show what I am looking at here. Thanks for any help.
The topic title has been edited to improve findability by @alina.balkanskaia. Original: From/To Reporting Not Showing Any Location Codes
Try to select (??) for both sides.
That did it, didn't even think to try the (??) just assumed that wasn't going to work. Now I see I have to Create/Edit a wire type then it will show up in that report that I can generate. Thanks!
Would your interconnect drawing be a one-line drawing?
And then again, arent' all connections between locations (location code/enclosure) cables? How about using cable markers? Then you could just get a cable from/to report.
Do you have an example of what you're trying to achieve? It's a little bit easier for me to help as I'm kind of "visual".
Send me a PM or e-mail ( t h l @ c t r l a l t e l . c o m ) if you don't want to share here.
Hello, @Zerb! Happy to see you in Autodesk Community! Thank you for marking the correct answer as the Solution because it will be helpful for other users in the future.😀
How to buy
Type a product name
