Form-C pinlist not populating
acclarkJR2TJ
Message 1 of 8
acclarkJR2TJ
Good morning all,
On multiple projects, I've tried to use relays with Form-C contacts.
The issue is that no matter what Form-C relay I use, the Form-C pinlist won't populate:
Anyone have any thoughts?
Replies (7)
Message 2 of 8
rhesusminus
I just tested, and it works as expected.
This only applies to Form-C contacts?
Is there a secondary database?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
acclarkJR2TJ
Hey, long time.
There isn't a secondary database, but for some reason, the pinlist isn't populating on the part correctly, even though I always go and link the part to the database.
When I went to the pinlist on the part itself, it shows up blank. Not sure, but it looks like part of my database isn't linking to the parts. 😞
Message 4 of 8
rhesusminus
Can you try to replace your database with the default one that comes with AcadE? I see that you open it in Access, so there might be some issues that has happened there.
Trond Hasse Lie
Ctrl Alt El
Message 5 of 8
acclarkJR2TJ
I can consider that, thanks.
Message 6 of 8
rhesusminus
Did it work with a fresh copy of the default_cat.mdb ?
Trond Hasse Lie
Ctrl Alt El
Message 7 of 8
acclarkJR2TJ
I haven't had a chance to test. We've made significant progress in adding parts to our database and cleaning out parts that we don't need. This isn't an easy task.
Message 8 of 8
rhesusminus
With AcadE.... No, it's not.
Trond Hasse Lie
Ctrl Alt El
