Form-C contacts default and reverse
Message 1 of 17
Good day all,
We are very happy with using ACADE for our railway interlocking system schematics, but so far we are creating new blocks and dynamic drawings between parrent coils and child contacts some troubles occour.
In base we have pinlist 3,11,12,13;3,21,22,23; ......... so no voltage on coil means NO is 11-12 and NC is 11-13.....
In our schematic logic is very common that if we have arrow (in our case in Description2 attribute) under parrent coil there is voltage on coil and we sign NO like 11-13 and NC 11-12 with arrow under contacts too.
I know this style of drawing electrical schematics is non-standard, but this is historicaly defined in our case.
Is it possible to make some script or advanced settings to reach this automatically: "If arrow symbol in Description2 in parrent then increase Pin2 +1 in all NO child contacts, decrease Pin2 -1 in all NC child contacts and so in 3 terms NONC contacts too" It means still NO and NC contacts but visible value is +1 or -1.
And yet one question. I have NONC contact (Form-C) with 3 Terms. What number will be on fifth character in symbol naming for NONC? NO is 1 and NC is 2 but 3 terms NONC definition is what number?
Thank you for answer.
Replies (16)
Message 2 of 17
dougmcalexander
Form-C contact symbol blocks are named HCR23 or VCR23. Symbols for these already exist in the IEC and NFPA library folders.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Message 3 of 17
rhesusminus
The number is 3.
And yes, I guess it would be possible to update whatever according to some rules you set.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 4 of 17
Thank you, but what rules and where i have to set up? 🙂 I know its advanced topic however where can i read this kind of solution?
Message 5 of 17
dougmcalexander
Use the Catalog Browser to edit the record for the part number of the relay. Look out to the right of the row for two fields, one for Coil Pins and the other for the Pin List. Click in the cell to get the menu for assigning pins, or you can type in - (i.e. 3,Common,NO,NC)
Doug McAlexander
Message 6 of 17
Doug, thx for your answers. My last question is clear now. But what about the previous problem:
Message 7 of 17
dougmcalexander
There is no built-in function for handling your request. There are options under Drawing Properties to show unused contacts, in case a 4PDT has extra contacts available.
Doug McAlexander
Message 8 of 17
rhesusminus
Can you supply some more information? Maybe a picture or two of what you have before and what you want after a macro has run?
Trond Hasse Lie
Ctrl Alt El
Message 9 of 17
Yes I will post pictures tommorow....
Now I have another problem with pop-up: Alert - pin aasignment repeated.
When I copy child contact symbol HCR21 or HCR22 and place with same pins - Alert shows - its OK.
But when I copy child contact symbol HCR23 and place with same pins - no Alert shows.
Its very useful Alert but I dont know why it doesnt work for NONC contacts...
PS: What is differrent when I use attribute NONC or NCNO in symbol editor? There is NO, NC and NONC choice in default but concretely symbol HCR23 has attribute NCNO.
THX for your answers...
Message 10 of 17
OK I have picture about my problem...
Again here is description:
And picture:
Message 11 of 17
Icemanau
There may be an easy way to do what you are after...
Edit the catalogue and copy the entire entry. Now modify the copy by changing the PIN LIST to show as if the coil is powered along with adding a ' POWERED' or similar to the catalogue number and stating the coil is shown powered in the description.
Now when you the catalogue number for the relay, you select the powered or unpowered version and the contacts should come in correctly without messing around with scripts, post processing or anything else like that.
Regards Brad
Brad Coleman, Electrical Draftsman
Message 12 of 17
Thank you, this is the way using catalogue with another pin list row. But its not so clear because there is two same component in catalogue anyway.
If anyone have Idea about some script, it would be fine 🙂
THX
Message 13 of 17
rhesusminus
This can be programmed, but unfortunately, I don't have time to do a freebie for a while.
Trond Hasse Lie
Ctrl Alt El
Message 14 of 17
Thank you,
I know its advanced issue and I agree with you 🙂
However is ther any chance to study this issue..any websites with autocad scripting?
Message 15 of 17
I tried the solution by Icemanau with UNPOWERED and POWERED pin lists.
Everything looks good, pins are distributed exactly from wanted pin list, but if I decide to change between unpowered and powered catalogue device, the Alert appears:
It is very unpracticle surf every child contact and change their pins 😞
Do I something wrong? Or can be there other solution to reach this effectively?
Many thanks
Message 16 of 17
Icemanau
No, you did nothing wrong and there is nothing that can be done about the warning.
It comes up whenever you change the catalogue selection and is normal for ACADE.
As for surfing to find each contact, I posted this idea a while back about the Pin List...
https://forums.autodesk.com/t5/autocad-electrical-ideas/contact-pin-selection/idi-p/5610401
Regards Brad
Message 17 of 17
Rhesusminus...for awhile or forever? 😄
Is there any chance to discuss the solution with you? What would break a freebie in your case?
