I would like to see an update to the pin selection when editing a parent or child block.
Currently when editing a child, you can select from a list of pins (if the pinlist is set), but you can only do so for the current child being edited.
What would be nice is the ability to modify the pins selected for other child blocks when in this list.
For example, a client wishes to use a specific contact for indication but only informs you after the contact is assigned to another function.
Currently the workflow is to edit the required contact, change it's pin numbers, cancel the alert about duplicate pins,exit the block. Then find and edit the other contact so there are no duplicate pins.
If we could edit one contact and bring up the pin list, select a contact pin set and move them to the correct contact in the list, then select the next pin set and move that to another contact and so on, it would make this so much easier for the user.
This dialog box should also be available from the parent editing dialog box as well.
Regards Brad
