AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
export \Import drawing properties as spread sheet
1 REPLY 1
697 Views, 1 Reply
Export Drawing properties to spread sheet in vb.net...
And Import Drawing Properties from Spreadsheet in vb.net..
How?
1 REPLY 1
rhesusminus
There is no API for this (as far as I can find), and the AEEXPORT2SS command doesn't support scripting.
So, the only way to do this via VB.NET, is to manually read the WDP-file/MDB-file, and to read the WD_M-block int the DWG's.
Find what you need, and write the changes back to the same place.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
