There is no API for this (as far as I can find), and the AEEXPORT2SS command doesn't support scripting.
So, the only way to do this via VB.NET, is to manually read the WDP-file/MDB-file, and to read the WD_M-block int the DWG's.
Find what you need, and write the changes back to the same place.
Trond Hasse LieEPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt ElPlease select "Accept Solution" if this post answers your question. 'Likes' won't hurt either.
