DSUB Panel Connector Drawing
EliseMoss
EliseMoss
I want to create a wire harness drawing using a DSUB connector. I have a native AutoCAD DB9 drawing. I used symbol builder to add the attributes, but when I insert it into a drawing the ADD CONNECTOR PINS command doesn't work. I want to be able to add the pins, so my BOM is correct.  I have attached the drawing.
What am I missing? TIA for any guidance.
rhesusminus
Are you looking to add the part numbers for the pins in the plug, so that the BOM is correct?
That is part of the MFG/CAT/ASSYCODE attributes (or most likely multi-cat in your case).
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
rosie_lucas1
Hi @EliseMoss,
I wanted to check in and see if you saw @rhesusminus follow up question and if assistance is still needed or if you found a solution to your question already? Please share any available information so the community can assist you further.
All the best,
Rosie | Community Manager
EliseMoss
@rhesusminus
How would that work? I thought if I added pins to the connector as child components then the contacts would appear on the BOM. Otherwise, why even have the Add Pins as an option?
@EliseMoss - this post has been edited to add user tag.
EliseMoss
Thanks, Rosie. Trond's response skipped past me. I get literally 100s of emails a day and it is easy for one to get by.
rhesusminus
You should be able to add the pins as child objects. Make sure you add the MFG/CAT attributes so that they can hold the part number for the pins.
The Add Pins command is maybe not what you think it is. It's there to add pins/connection points in your plugs, so that a wire can be connected.
Trond Hasse Lie
Ctrl Alt El
rosie_lucas1
Hello @EliseMoss,
Did the information provided by @rhesusminus help you and answer your question?
If yes, please click on the "Accept Solution" button. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
Rosie| Community Manager
