Cable To/From Report
EliseMoss
EliseMoss
I can't get a To/From Report to generate for my cable drawing because I don't have any cablecon*.set files to start with. I did a search and didn't find any. Any ideas on how to generate one?
TIA for any guidance,
lauri_barnhart
Hi @EliseMoss,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Lauri | Community Manager
EliseMoss
I actually figured it out. You need to use a tool to create your set file that you can then use to create your reports.
