AutoCAD Electrical Forum
Drawing template issues since 2013
3 REPLIES 3
478 Views, 3 Replies
Has anyone else had random parts of the drawing template being changed since the introduction of AE2013.
I have lines and company logo missing, which was generated as part of the original .dwt file.  The only was I can find to correct it is to copy and paste the circuit from the corrupt file into a blank sheet and rename it.
Does anyone hgave any idea what might be causing this.
3 REPLIES 3
Looking at it further, it would appear the TITLE_BLOCK has changed somehow.  When I insert it into another drawing, the logo and grid lines display correctly.  I also deleted and purged the block from the drawing with the error, and inserted one from a different sheet and it was the correct one, with all grid lines and company logo.
What causes it to be changed in the first place though?
Icemanau
Did you check for layers that are turned off?
I've noticed that that when I import Layer settings, that layers not in the incoming settings get turned off even if they have objects on them. You may have something similar happening.
Regards Brad
Brad Coleman, Electrical Draftsman
No, this was the first thing that I looked at.  All layers are turned on.
Technology Administrators
AutoCAD Beta
