Disappeared diagram tab
Message 1 of 10
First of all sorry for my English, I'm french. My name is Enzo, student and trainee in Enterprise Trifyl. I have a little problem with AutoCad Electrical and I really need help for finish my project. So, the problem is that the tab "schema" disappear and I don't know why... I really need that tab that's why I need your help. Thanks you.
Replies (9)
Message 2 of 10
Icemanau
If you are refering to one of the ribbon tabs, RIGHT CLICK in the grey area to the right of any of the tabs.
Select the Tabs entry from the menu that comes up.
Make sure that there is a checkmark next to the Tab you require.
If the section you want isn't showing in the Tab it should be in, you again RIGHT CLICK on the grey area while in the relevant Tab.
This time you select Panel and make sure the panel has the check mark next to it.
If you are refering to the Tabs to switch betwen dwgs, that is set in the ACAD Options...
Go to the BIG RED A in the top left corner and click on the little black arrow next to it.
Click on Options down at the bottom right and the Options will come up.
Click on the Display tab to get the page shown above.
Make sure the box I've underlined is checkd and click apply.
You should now have the File Tabs up the top of your dwg.
Regards Brad
Brad Coleman, Electrical Draftsman
Message 3 of 10
I tried all solutions that you give to me but it didn't work. I don't know what to do.
Message 4 of 10
Try right clicking next to the small grey up arrow and seef if you can find it there.
Message 5 of 10
Message 6 of 10
The last thing I can think of is if you are not is the correct work space.. I do not speak or read french so I can not read your screen shot as far as that goes. But on the top of the screen you should select what I have highlighted...
Message 7 of 10
I'm in correct workspace but i haven't the schematic tab.
Message 8 of 10
I found the solution : i wrote on the command line "chargiuperso" and i recharged all fonctions groups and the schematic tab come back. Thanks you for all of your solutions and for your time.
regards Enzo
Message 9 of 10
Now I have another problem. I can have the schematic tab but the icons doesn't work and there is no picture for the function. I think that the icon aren't affect to a command. Someone can help me ?
Message 10 of 10
with the problems you are having it sounds like you have to do a reinstall, or fix installation. If you try to uninstall the program you can select the "Repair or Reinstall" tab and then try a repair... if that still doest work reinstall.
