Design
Design
ranjithkumarM7U35
Design
ranjithkumarM7U35
terminal footprint is smaller than the attribute and some times overlapping also. what to do?
dougmcalexander
Are you designing in metric or English units?  Is it a custom symbol that you created?  It would help if you post the affected drawing, with the symbol inserted.  We need to have a look at your drawing properties and panel configuration, which are hidden in the drawing.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor
Specializing in AutoCAD Electrical Implementation Support
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
arshdeepsingh404
Hi @ranjithkumarM7U35
Seems like a issue with the custom terminal footprint drawings. You will see results like this units gets mixed up i.e. inches vs mm.
Ideally you should fix it at the symbol level but for a quick check, you can try setting up the Scale on Insert: in the TSE to convert metric symbols to imperial and vice-versa.
1 inch = 25.4 mm
1 mm = 0.039 in
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CAPM | CMSE | Autodesk Expert Elite
LinkedIn | Autodesk App Store | GitHub
Did you find this post helpful? Please feel free to Like this post.
Did your question get successfully answered? Please click the Accept Solution button to help other users who may have the same question.
