AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Counting tips for the wires
8 REPLIES 8
Message 1 of 9
galashkina
638 Views, 8 Replies
Typically, electrical tips are used to connect wires to the terminals of the components. AutoCAD Electrical will be able to calculate the electrical tips based on the schema?
8 REPLIES 8
Message 2 of 9
rhesusminus
in reply to: galashkina
Do you mean ferrules?
They come in different sizes, so maybe add it as a user-field in the wire type?
Also, some components need a double ferrule when two wires are connected... This should be placed at the component level somehow?
AcadE does not have a default scheme for this, like the competition have unfortunately.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 9
in reply to: rhesusminus
Hi Rhesusminus, what file did you edit to change the header from user1 to ferrule?
Jim
Message 4 of 9
rhesusminus
Project properties:
Trond Hasse Lie
Ctrl Alt El
Message 5 of 9
If you are referring to the Ring Terminal to connect wire(s) to a terminal of a component, probably the best way to do is use suitable terminal symbol from "Terminal and Connectors" and define terminal p/n in the component level. Depending on the industry standard, as a default, normally a terminal of the component accepts upto 4 Ring Terminals ie you can terminate up to 4 wires (different AWGs) using suitable AWG Ring Terminal. Terminal Symbol also allows to add Multiple Catalog. This really handy when 4 different AWG wires are required to connect to a common terminal using different terminal (awg) sizes.
Message 6 of 9
Thanks!
Message 7 of 9
ccad2509
according to autodesk wires have one end
so if you have a wire that has a ring crimp one end and a bootlace ferrule the other how do you distinguish which end has which connection type ?
and how do you make sure your to from report is correct
Message 8 of 9
in reply to: ccad2509
I believe, it depends on how you are going to setup your project / drawings. I have shown a typical example, see attached.  Item 101 being Ring Tag (for stud termination) and 102 bootlace ferrule (for screw termination). FROM / TO perfectly works (change headings as required), see attached.
Message 9 of 9
galashkina
The picture is not clear.
Сan you attach  DWG file?
Thanks.
