AutoCAD Electrical Forum
COPY CLIP TOOL (CIRCUIT CLIPBOARD) is not working (NIL)
2 REPLIES 2
jesusrperezd
360 Views, 2 Replies
Hi there.
When I try to use the Copy clip tool on the Circuit clipboard toolbar it doesn't work. I select the base point, then select all the components to be copied, then press enter and nothing happens. The console shows that components were found but then indicates "NIL".  I have tried to do this in demo projects and mines without success. How can I fix this? Please check the attached screen capture. Thanks.
Console messages
Base point:
Select objects: 1 found
Select objects: nil
2 REPLIES 2
rhesusminus
in reply to: jesusrperezd
The video don't show what you think it's showing.
But, after COPYing the circuit, you must also PASTE the circuit.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
jesusrperezd
I'm so sorry for this 🙂
