AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Contacts type "Undefined"
27 REPLIES 27
Message 1 of 28
galashkina
1466 Views, 27 Replies
Good day!
I have not had to use in real projects contacts of the type "undefined" (type 4).
I figured out how it works and decided that was enough.
I now have to deal with it seriously.
Here are my results:
Description PINs in the database:
Do you use type 4 contacts ?
Please share your experience.
27 REPLIES 27
Message 21 of 28
Message 22 of 28
Thanks for the info, but a silly question where do I find the table
Message 23 of 28
I must be missing something as I do not seem to get this to work
Message 24 of 28
I'm sorry, I don't speak much English, so I'm writing briefly.
You need to select the tabular format of cross-references and click the "Install" button.
Select "Table of graphic images" and click"Edit".
You need to add the lamp to the table.
Message 25 of 28
Then do the following:
1. Place the lamp.
2 Assign the catalog data.
3. Place the contact and assign it a parent component (lamp).
Pin numbers must be specified in the catalog data.
Message 26 of 28
Thank you @galashkina that is fantastic.  My settings were set to Graphic so had to change to symbol mapping.
Best Regards
Andy
Message 27 of 28
Message 28 of 28
@andrew.thompson wrote:
 that is fantastic.
 that is AutoCAD Electrical  😊
