Good day!
I have not had to use in real projects contacts of the type "undefined" (type 4).
I figured out how it works and decided that was enough.
I now have to deal with it seriously.
Here are my results:
Description PINs in the database:
Do you use type 4 contacts ?
Please share your experience.
I'm sorry, I don't speak much English, so I'm writing briefly.
You need to select the tabular format of cross-references and click the "Install" button.
Select "Table of graphic images" and click"Edit".
You need to add the lamp to the table.
Then do the following:
1. Place the lamp.
2 Assign the catalog data.
3. Place the contact and assign it a parent component (lamp).
Pin numbers must be specified in the catalog data.
Thank you @galashkina that is fantastic. My settings were set to Graphic so had to change to symbol mapping.
Best Regards
Andy
