- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I saw a post a while ago explaining this but I can't find it now that I have the issue. We first insert a parametric PLC module, then I have a saved circuit to insert the IFM modules. My issue here is why 1 is tagging the IFM module based on rung 020 and the other on rung 010 as you can see in my screenshots attached. My blocks in the screenshots are in the same location (i draw a line across and they are even horizontally).
Can someone guide me on what is being used to tag these, and why it might be using different lines?
Thank you for the help.
