catalog Siemens PLC
catalog Siemens PLC
catalog Siemens PLC
Hi everyone,
I've AutoCad  ELECTRICAL 2015,
I've updated my catalog with brand Siemens, but when I insert a PLC module and try to choose from catalog I don't find the PLC Siemens, just only ABB, AB & Telemecanique.
Has someone some suggestion? Talking about PLC  there are only the three brand mentioned before?
thanks a lot!
You need to update your installation program.  Go to Windows Control panel, Programs & Features.
Then select your AutoCAD Electrical installation program, then 'Uninstall/Change' which should take you to 'Add/remove Feature' - included in this is selecting which manufactures you want to add or remove from your installation.
Hope this helps.
hi,
I've already done it...I see that I upgrade the catalog but in ace_plc.mdb don't find the Siemens PLC series...
bye
DT
jalger
For AutoCAD Electrical 2015 the add/remove method tends to not work all the time.
Sadly, in this case I would recommend Uninstalling then re-install with all of the libraries you want to use.
You can try re-intializing it. ( sometimes this works, but honestly it takes less time to re-install)
1. use the "Reset to Default Settings..." tool (make sure the program is working properly)
2. In control panel "add/remove",  select your Libraries
3.  use the "Reset to Default Settings..." tool (to reload the libraries
4. restart the computer, then start the program and check
I hope this helps,
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
good suggestion... in the next days I'll try.
will let you know
Davide
hi everyone, I'm come back!
the good new is I've got the goal!
I followed the suggestion:
1) reinstall ACADE
2) update the Library.
now I have all library I've choosed for PLC (siemens etc..)
thanks a lot to everyone!
Davide
