Cannot convert source arrow xref to multi-line
Message 1 of 8
I have just updated from 2013 to 2017 and am not able to change a long string of cross reference line numbers to multi-line.  I am working with a project that was created using 2013, and the text was multi-line then.  Do I need to do some kind of project update?
Replies (7)
Message 2 of 8
TRLitsey
Hi there,
Is this what you are looking for?
Good luck
Please mark as a solution if this works for you, kudos are always welcome
Message 3 of 8
TRLitsey
Or to say it another way ...
Message 4 of 8
I was getting an error in the command line notification error that the text was "not an ATTRIBUTE (you selected MTEXT)". It was already an MTEXT type but the box had been re-dimensioned. I was able to manually put carriage returns into the text area with the enter key but it still wouldn't resize when I dragged the box arrows around.
Brett Ellis
Weigh Price Labeling
Ossid LLC.
www.ossid.com
4000 College Rd
Battleboro, NC 27809
Toll Free: (800) 334-8369 x164
Direct: (252) 446-6177 x164
Cell: (252) 399-9207
Fax: (252) 442-7694
Message 5 of 8
TRLitsey
I am not clear on this.  Are you just trying to resize area or edit the text?  Is your full tool bar for mtext edit open?  To turn the tool bar on right click in the text box to open the dialog.  And if it is just the box, to you make the size change and then click outside the box?  If you do not exit the editor correctly it will not save the edit, just go back to what it was when you started.
Good luck
Screenshot - 1_20_2017 , 9_12_29 AM.pngScreenshot - 1_20_2017 , 9_13_17 AM.png
Message 6 of 8
jseefdrumr
I think I understand what is going on here.
When you first change xref text to mtext, ACADE does so without any adjustments to the size of the text area. It will remain the same visually until you do the following:
1. Click into the text as if to edit it. You will see a box around it that represents the text's 'area'.
2. One corner of that area will have little arrows for resizing. At first, they are right on top of one another. Grab one and drag it over.
3. You should now be able to see the hash marks on the ruler, if it's enabled. If not, you should at least see some distance between the arrows. You should also see the text respond accordingly as you drag back and forth.
4. Set it up the way you need it and exit out of the command. Now click on it again. As if by magic, the normal mtext grips are now the way you are used to seeing them. They weren't there before because they were geometrically coincident with each other (meaning they shared the exact same coordinates in space). Their coincidence also prevented you from resizing with the grips.
Hope that helps,
Jim
Jim Seefeldt
Electrical Engineering Technician
Message 7 of 8
That is the correct method, and works fine on an unmodified signal reference until an "Update Signal Reference" is done. At that point, the text will not only loose all previous adjustments made, but also loose the original default width factor - sometimes causing the insertion point to shift. The command no longer works, as described by the OP, because it is already MTEXT. The only solution I can think of would be upon an "Update Signal Reference" command to have any MTEXT revert to single line text, perform the update, and go back to saved adjustments; or enable ACADE to work with multiline text without changing the current settings.
Message 8 of 8
rhesusminus
Hi!
I believe this behaviour was due to a change in AutoCAD (vanilla) on how automatic line breaks in MTEXT's should occur. Previously, it would break to a new line when it found a comma, but it don't do that any longer.
It will however, break on a "space". So, what I've done, is to add an extra space at the end of the cross referencing format, making the multi-line cross references break as expected. Here's my settings.. not the extra space in "/%S.%N ":
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
