AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Blocks
3 REPLIES 3
351 Views, 3 Replies
Blocks
Where are Acad electrical blocks store on the C drive? I would like to modify some of the blocks that are included in the program and share with others
Blocks
3 REPLIES 3
TRLitsey
TRLitsey
If it is a default install look here:
C:\Users\Public\Documents\Autodesk\Acade 2014\Libs
You my see multiple directories if you are loaded with more than one version of Acade.  I use the blocks in the jic125 directory.
Good luck
Kudos are alway welcome
Please mark as a solution if this works for you, kudos are always welcome
Good luck
TRLitsey
TRLitsey
And by the way, you can also open the ACE Options window to see which folders your application is using for resources ...
in reply to: TRLitsey
Thank you so much!
Thank you so much!
