Where are Acad electrical blocks store on the C drive? I would like to modify some of the blocks that are included in the program and share with others
Solved by TRLitsey. Go to Solution.
If it is a default install look here:
C:\Users\Public\Documents\Autodesk\Acade 2014\Libs
You my see multiple directories if you are loaded with more than one version of Acade. I use the blocks in the jic125 directory.
Good luck
Kudos are alway welcome
And by the way, you can also open the ACE Options window to see which folders your application is using for resources ...
