Automatic Filling Title Block with Index/Table of Contents From Different .dwg File
asherwinR3MQW
asherwinR3MQW
I have just gotten into AutoDesk Electrical. I have been tasked with auto-filling a standard company template's title block contents for each .dwg diagram from information in a .dwg file with an index/table of contents (title, sheet number, drawn by, section number, revision etc.).
Does anyone have suggestions on how to do this? Fields was something I was looking into, but I am not sure if that can access information in a specific cell in the index from anther .dwg file.
Thanks for your help.
rhesusminus
As far as I can understand your question, this cannot be done automatically. Normally it's the other way around. You put information into all the DWG's and then you generate the table of contents.
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
asherwinR3MQW
I have been digging around looking for a solution, and I was wondering if Title Block Setup and using an Attribute is the solution? Thanks.
rhesusminus
Yes. You should set your title block up according to how AcadE wants it. Then, you can extract the information automatically later.
Trond Hasse Lie
Ctrl Alt El
arshdeepsingh404
Hi @asherwinR3MQW
@rhesusminus has already answered your main question.
If you need additional help on setting up Title Block, see the following thread. Another user has similar question on mapping descriptions to Title Blocks.
https://forums.autodesk.com/t5/autocad-electrical-forum/project-setup-questions-from-a-new-autocad-e...
Some of the Attributes you are looking for Like Drawn By, Revision, and anything that is same for the whole project, you would be able setup in Project Descriptions and Update all drawings using Title Block Update command altogether.
Arshdeep Singh
Electrical Designer & Programmer
C.Tech | CMSE® | Autodesk Expert Elite
LinkedIn
asherwinR3MQW
Your link was very helpful, thank you
lee_kirkup
What you are asking to do can be done in a way.  Not automatically, but in a couple of easy to do steps.
Setup, once done, you wont need to do again.
Setup Step 1.
You will need to add 2 hidden attributes in your title block as follows
Tag: TAG1 > Prompt: DO NOT EDIT > Default: TITLE
Tag: LOC > Prompt: DO NOT EDIT > Default: TITLE
Setup Step 2.
Add user defined Attributes to the DEFAULT.wda file and save it in wd.env file location.
Enter AEUDA then select each title block attribute that you want to export.
Complete all fields then Save-As DEFAULT.wda in the wd.env file location.
Hint: Select the attributes in the same order that you have them in the table you will create.
This will make the copy and paste bit a lot easier.
The Final Process
Step 1
Create your table as required.
When finished use TABLEEXPORT to export the table to a CSV file.
Step 2
Use Export to Spreadsheet > Components > Named Location = TITLE
And export the title block component from all drawings in the Project.
Step 3
Now copy and paste the exported table data into the exported components spreadsheet.
Step 4
Use the Update from Spreadsheet to import all the component data back into the title block for all drawings in the Project.
