AutoCAD Error Aborting
Message 1 of 18
Since (January) we are using ACE2016. Before January we are using the ACE2014 version.
Since we using ACE2016 we have a lot of internal and fatal errors. For example see attchment.
This error we get when changing or updating a component.
Does anybody recognize this? Does anyone have an idea / solution?
Regards
Replies (17)
Message 2 of 18
rhesusminus
NOt much to find on that error.
Could it be some add-ins that you have installed?
Type APPMANAGER at the command line, and see if you have some strange add-ins installed.
Does this happen to multiple computers?
Have you tried running a reset? https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 18
The apps we have, are only the pre-installed Autodesk apps.
Yes, it happens to more computers.
We have a brand new and clean computer system. After the first errors we have also tried the reset function.
Regards
Message 4 of 18
rhesusminus
Do you have admin rights with your user on the computer? Can you try to work a little with an admin user?
Trond Hasse Lie
Ctrl Alt El
Message 5 of 18
I have admin rights.
When I want to run as administrator there pop-ups an alert. Alert attached.
This is the path were the .arg file is stored.
"C:\Program Files\Autodesk\AutoCAD 2016\acad.exe" /language "en-US" /product "ACADE" /p "O:\Autodesk\Acade\Profile\ACADE.arg"
Regards
Message 6 of 18
rhesusminus
And... O:\Autodesk\Acade\Profile\ACADE.arg actually exists on the server?
If you run with the standard AcadE profile "<<ACADE>>" does it work as expected then?
Trond Hasse Lie
Ctrl Alt El
Message 7 of 18
ACADE.arg exists on the server.
The profile I'm using is already <<ACADE>>. See attachment.
Regards
Message 8 of 18
rhesusminus
What OS are you running? Is UAC disabled? How about anti-virus, are you able to disable that for a while, while testing?
Trond Hasse Lie
Ctrl Alt El
Message 9 of 18
We are using OS Windows 7. See attachment.
UAC is not disabled. See attachment.
It is posible to disable the antivirus for a while.
Regards
Message 10 of 18
rhesusminus
I would try to work without anti-virus for a while.
Does it happen in all projects?
Trond Hasse Lie
Ctrl Alt El
Message 11 of 18
I would like to try it for a couple of day's.
To protect our systems we have installed Trend Micro Security Agent. We use this anti-virus now for 8 years.
Yes it happens in all projects.
...last friday there pop-ups an another error! See attachment.
   This error came when I use the function edit component.
   Do you like to receive the details of this error. Wow, it will be a lot of pages.19 pages!
Regards
Message 12 of 18
rhesusminus
If you press the "Details-button", you usually get an idea of what went wrong from the topmost description.
Was this with anti-virus ON or OFF?
Trond Hasse Lie
Ctrl Alt El
Message 13 of 18
Thats right, it shows me the description.
Thats was with anti virus on.
The anti virus is now switched off. I will work today without anti virus.
Regards
Message 14 of 18
Last week, I have tested a lot of drawings.
The error is not solved!
Regards
Message 15 of 18
rhesusminus
@VinodBalasubramanian maybe you can check up on this one...
Trond Hasse Lie
Ctrl Alt El
Message 16 of 18
Thanks for your support.
Do you know when I can get a response from Vinod?
This problem is very annoying.
Regards
Message 17 of 18
rhesusminus
I would be nice if you could have a look at this one.
Trond Hasse Lie
Ctrl Alt El
Message 18 of 18
Autodesk Support
Autodesk Support
Sure no problem.
HVEE,
May I know where you are based out of and also if you could PM your contact details and your convenient time. I would arrange a call from my end.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
