- Mute
- Permalink
- Report
Hello everyone. I’ve run into an issue with schematic bill of materials (BOM) reports. The default report layout leaves much to be desired, as each element occupies a separate position within a single line. I managed to configure the report (using a custom function) so that elements are listed with commas and multiple items fit into a single column. However, this approach fails when there are too many elements. Is there a way to format the list like "KL1...KL22, KL26, KL28"? Also, I need each new entry to create a new row rather than expanding the existing one. Perhaps someone has already solved this problem and can point me to a relevant discussion?
