AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
autocad electrical 2019 could not find catalog database
9 REPLIES 9
Message 1 of 10
2161 Views, 9 Replies
I went downloaded several of the catalog database vendors and when I open a drawing and click on catalog database I get the following message "Could not find catalog database". I downloaded all the default way but to no avail. I've attached photos of the 2 things that pop up when I click on "Catalog Browser".
9 REPLIES 9
Message 2 of 10
testsubject
Would you check and see if this filepath is in the Options\Files tab under Support File Search Path?
C:\users\{username}\Documents\Acade 2019\AeData\en-US\Catalogs
This is the default filepath for the catalogs.
Double check that this is the location where the catalogs where downloaded.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
Message 3 of 10
in reply to: testsubject
After some searching, they were downloaded to
C:\Users\Public\Documents\Autodesk\Acade 2018\Libs\panel_mm
And I apologize, it's actually the 2018 version.
Message 4 of 10
testsubject
No problem. I am glad you found them.
Bob Hanrahan
Ace User since 1998
Message 5 of 10
How do I get them to link from the file to my Catalog Browser?
Message 6 of 10
testsubject
If you Right Mouse Click on the Project and select settings, you will see where the database location is.Catalog path.png
My location is different from yours but the highlighted setting is where you will find it.
This is where the database has to be for ACE to see it. This location can be changed by editing the wd.env file which can be found by clicking on "Environment File" in the lower left corner of this dialog box.
Bob Hanrahan
Ace User since 1998
Message 7 of 10
ChrisPreece
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @testsubject provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Chris Preece
Technical Support Specialist
Message 8 of 10
in reply to: ChrisPreece
I’m still trying to sort it out and have been out in the field. I haven't has too much time to mess with it. I didn't see and couldn't find settings anywhere under Projects. I’m new to AutoCAD Electrical so no that savvy. Will try to mess with it more as soon as i button up this project.
Message 9 of 10
testsubject
No problem.
When you Right Mouse Click on an existing project, you will get the following list:
Near the bottom is "Settings"
Bob Hanrahan
Ace User since 1998
Message 10 of 10
I don't have any existing projects. I was just working on projects from our server. When I click on "New Project", I get a triangle with an exclamation point and no text describing what the error is.
