AutoCAD Attribute: Hyphen invisible when using Alt+0173 (soft hyphen)
bryanchanYHRV2
Observer Observer
Message 1 of 8
bryanchanYHRV2
Observer
Observer
In AutoCAD, I created a hyphen using Alt+0173 in a block attribute (TAG1, value should be -F52/1). In the Enhanced Attribute Editor, the value shows the hyphen correctly, but on the drawing screen the hyphen is invisible - I only see "F52/1" without the dash.
Replies (7)
Message 2 of 8
rhesusminus
Is this setting turned on?
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Autodesk Expert Elite Alumni
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Message 3 of 8
AQILAHQJB6W
I am facing the issue of missing hyphen above. Attached below is the default setting after ACADE 2025 is installed.
Do you suggest to turn off the Suppress dash when first character of tag? If yes i have tried it and outcome as follows - there is 1 dash and 1 missing hyphen in the drawing space:
I am looking for a visible hyphen where it should be located at the center of the tag per example below:
FYI, I am using ACADE 2020 with the following TAG setting but no issue with invincible hyphen in the drawing space.
is there any setting that i need to check?
Your suggestion is much appreciated.
Message 4 of 8
rosie_lucas1
Hi @bryanchanYHRV2 ,
I wanted to check in and see if you saw @rhesusminus follow up question below the screenshot that was provided? Did it help resolve your issue? Is assistance still needed or have you found a solution to your question already? Please share any available information so the community can assist you further.
All the best,
Rosie | Community Manager
Message 5 of 8
AQILAHQJB6W
Hi @rosie_lucas1 ,
@bryanchanYHRV2 is posting this issue on behalf of vendor's customer which is me. I have replied to @rhesusminus feedback using the solution suggested but it is not working as expected. The soft hyphen is still invincible in the drawing space. You can refer my reply thread to @rhesusminus.
Feedback from the community is highly valued to resolve this issue asap.
Thank you.
Message 6 of 8
jaya_priya_ramasamy
Please run the command GRAPHICSCONFIG and do either one of the following to get the special characters displayed correctly.
1. Turn the hardware acceleration Off
2. Keep it on and change 2D display settings to intermediate mode
Jaya Priya Ramasamy
Senior QA Analyst
www.autodesk.com
Message 7 of 8
AQILAHQJB6W
Hi @jaya_priya_ramasamy , thank you for sharing the solution.
The desired soft hyphen is now available in the drawing space.
Thank you! 😊
Message 8 of 8
rhesusminus
May I ask WHY you use the soft hyphen? According to IEC you should use "minus" or "dash" - (Just like IEC specify the usage of plus + and equal 😃
Trond Hasse Lie
Ctrl Alt El
