Attribute XnPINn
Attribute XnPINn
galashkina
Advisor Advisor
Attribute XnPINn
galashkina
Terminal block with the number HT0002 contains attributes X2PIN01, X4PIN01, X1PIN01, X8PIN01. The note did not find any information about these attributes. What are they used?
testsubject
In IEC, you not only assign a Terminal number to each Terminal (including each level in a 2/3 level terminal block) but you also can assign a nunber to each side of the terminal. Thiat information is be stored in the X#PIN## attribute.
For example, say we assign the top screw of a terminal (we will call this TB10)  to 1 (X2PIN01=1) and the bottom to 2 (X8PIN01=2).
Then, when running a To/From report, it would report a wire connected to the top of the terminal block to TB10.1 and to the bottom TB10.2.
This allows the designer to be very specific as to where a wire is landed on the terminal. (Since you can draw the schematic so that it depicts exactly how the system is wired.)
Also, the X# value represents its position on the block
X1 is Right.
X2 is Top
X4 is Left
X8 is Bottom.
Bob Hanrahan
Ace User since 1998
Autodesk Expert Elite Alumni
If this answered your question, please click on "Accept Solution"
galashkina
For example, terminal XT1 1 has two levels: top and bottom (pic1), pin numbers 1, 2, 3, 4.
These pin numbers are not the values of the attributes of the block terminals NT0002 (pic2).
Can I display the pin numbers in the drawing and report?
testsubject
Can you post the image of pic2. I do not see it.
Bob Hanrahan
Ace User since 1998
galashkina
I've had problems with attachment figures.
I have two signs made one
pic1=pic1+pic2
