In IEC, you not only assign a Terminal number to each Terminal (including each level in a 2/3 level terminal block) but you also can assign a nunber to each side of the terminal. Thiat information is be stored in the X#PIN## attribute.
For example, say we assign the top screw of a terminal (we will call this TB10) to 1 (X2PIN01=1) and the bottom to 2 (X8PIN01=2).
Then, when running a To/From report, it would report a wire connected to the top of the terminal block to TB10.1 and to the bottom TB10.2.
This allows the designer to be very specific as to where a wire is landed on the terminal. (Since you can draw the schematic so that it depicts exactly how the system is wired.)
Also, the X# value represents its position on the block
X1 is Right.
X2 is Top
X4 is Left
X8 is Bottom.
Bob Hanrahan
Ace User since 1998
Autodesk Expert Elite Alumni
If this answered your question, please click on "Accept Solution"
