Active Drawing BOM Report - No data to Display
This widget could not be displayed.
HI,
For some reason, I get "Schematic Bill Of Material extraction/report No data to display" when I try to generate report for an active drawing. But it works when I use "Project wide".
I looked at some old post and it says to delete the [projectname].mdb and restart autoCADe. I did so, but the .mdb did not regenerate and I am still getting the message "no data to display".
This function for Active drawing has been working until now, so I am not sure what has changed.
Chris
chris.downing
Can you attach a copy of the drawing?
ACADE & PLANT3D Applications Engineer
CAD Training
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
rhesusminus
I'd look into removing the KB4484127 update, that has caused a lot of problems related to databases.
https://knowledge.autodesk.com/support/autocad-electrical/troubleshooting/caas/sfdcarticles/sfdcarti...
Trond Hasse Lie
EPLAN Expert and ex-AutoCAD Electrical user.
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
Thank you. I have been having this same problem. I also had terminal strips disappearing from the Terminal Strip Editor after a QSAVE popup window appears. Uninstalling Update KB4484127 fixed that problem also.
Yes, the update was the issue.
Thank you,
