Show only
Search instead for
Alrighty then, figured out which fields in the components to map in order to get clean PS Items but I haven't found any editable properties in the ACAD E project that I can use for mapping. Anyone else gone thru this and can lend a hand?
Eric
Eric
SysSpecs
IV 2008Pro SP3 - PS2008 (Admin) - WinVistaBusiness64 SP1 - Xeon 4core 1.86GHz64
8GBRAM - NVIDIA Quadro FX 4600 (driver 7.15.11.6002 - 4/26/2007) 768MB
ACAD E 2008
I'm also having trouble with Detail ID's. Bubble numbers are good in ACAD, the Project BOM lists the bubble numbers OK too. However, when assigning the Item I only get Detail ID for one Item (component), the others are left blank for some reason.
