About some issue that i dont know or bug maybe
battushigwork
Message 1 of 10
battushigwork
Some of my wife layers changed in shape that i choosed in all my drawing file.  i choosed zig zag linetype but it changed into weird shaped wire layer how can i solve this please help me?
Replies (9)
Message 2 of 10
arshdeepsingh404
Hi @battushigwork
Can you post a screenshot or the dwg file with issue?
Sometimes its just looks weird and all you need to do is run the REGEN command to regenerate all geometry.
Have you also tried selecting the linetype and changing the linetype scale under properties?
Arshdeep Singh
C.Tech, CMSE®
Message 3 of 10
battushigwork
Hello? Yes i tried both of them but it doesnt change
but i looks like thisbut i looks like thisbut i looks like thisbut i looks like thisbut i looks like thisbut i looks like thisit should looks like thisit should looks like this
Message 4 of 10
arshdeepsingh404
Any chance the arrows in the linetype are text?
If they are text then having the Height defined other than 0 can affect how it looks.
Just give this a quick try, Make a backup copy of your drawings, Type in STYLE command and set the Height to 0.0000 for every text style.
Arshdeep Singh
C.Tech, CMSE®
Message 5 of 10
battushigwork
The arrows are linetype sir.
Message 6 of 10
battushigwork
i mean its not text
Message 7 of 10
arshdeepsingh404
So you mean the arrow in the line type is geometry (lines and hatch/ poly line) and not any type of font.
Can you post the drawing file with the problematic linetype?
Arshdeep Singh
C.Tech, CMSE®
Message 8 of 10
battushigwork
This is the file that are problematic
i used it other PC it shows same i hope its some setting issue
i really need to fix it thank u for ur help!
Message 9 of 10
arshdeepsingh404
I was able to get the Zig Zag LineType working. Try the following steps:
1. Open drawing
2. Run the PURGE command and purge all items till there is no else left to purge.
3. Save drawing and close AutoCAD
4. Relaunch AutoCAD and open the drawing again.
See the following article for more details on this issue:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Bad-definition-of-...
Arshdeep Singh
C.Tech, CMSE®
Message 10 of 10
battushigwork
thank u so much it works sir ❤️ wish u best in new coming year
