@Anonymous wrote:
We ran into this same problem. 2017-2018 Civil 3d started caching DREF into the drawings that they were being referenced into. To me that completely ruins the point of a DREF. To fix the problem follow the steps on the site below except change it to NO:
http://cadpanacea.com
I appreciate the attempt to help, @Anonymous. :beer:
I've already done that, but it only helps with new drawings, and doesn't seem to do anything for drawings that have already been setup to consume the DREF surface (i.e., Profiles, Volume Surfaces, etc.) as changing that setting does not 'un-cache' the surface(s). Setting Store DREF==NO after referencing a surface should 'un-cache' any/all DREFs at next sync, IMO (and that is NOT happening, as I've tried it on several DWGs w/DREF surface).
The trade off is not having surfaces cached just slows down the opening of drawings again with one or more large surfaces referenced. Neither is really a viable solution; one is slower but takes up less network space (Store DREF==No), the other is faster and takes up more network space (Store DREF=YES).
Even with the surface cached to .MMS file, setting the overall surface to 'no display' and having a handful of smaller surfaces with the overall surface pasted into it and a boundary for just the vicinity I need, with a handful of flood stage surfaces to compare against, then a volume surface for each respectively jumps my drawing up to 259 MB DWG + 65 MB MMS.
I can keep the drawing size smaller - down from the 259 MB DWG to 53 MB DWG - by applying a Hide boundary and multiple Show boundaries to accomplish same (rather than one smaller surface for each wetland crossing), but at the end of the day, the same data is being used as I still need individual flood stage surfaces for each to create the Volume surfaces, and those volume surfaces still have the same Hide and Show concept applied that they already had.
The fact that the drawing is smaller for the same smaller surface areas suggest a big problem under the hood, as I completed the exact same calcs for each (the larger 259 MB + 53 MB DWGs); the larger being an easier setup for DREFing individual areas to keep my sheet drawings smaller, and the latter bloating my sheet drawings (never mind the MMS file issue, were that to propagate as well with Store DREF==YES).
I'm glad the Autodesk team took my and others' recommendations to leverage external database to speed Civil 3D up where it makes sense to (i.e., best of both worlds for LDC + C3D + Modern workstations), but this whole MMS business is a train wreck.
Cheers
